Old 10-29-2009, 11:37 PM   #1
Default water heater wont stay lit Help
I have a Richmond gas water heater the pilot went out and now when I light it the pilot will light and stay lit until I adjust the temp. As soon as I turn it up any at all you can see it light and then it goes out even the pilot I was told it was the thermocoupler but I replaced it and it is still doing the same thing Please help I have two kids and need my hot water back
mdka is offline   Reply With Quote
Old 10-30-2009, 08:09 AM   #2
Make sure the thermcouple tip if fully in the pilot flame, and that the flame is high enough, and blue(not yellow). Also not a bad idea to clean out around the pilot and burner.
Old 10-30-2009, 11:44 PM   #3
If it has a yellow flame it may be that that it not getting enough air due to dirt or spider webs and the oxygen depletion unit is shutting it down. A blast of canned air down the pilot tube will generally clean it out and you'll have a blue flame when you relight.
hayewe farm is offline   Reply With Quote
Old 10-31-2009, 07:47 PM   #4
Also check the gas valves and be sure they are all open 100% I have seen that same thing happen because someone turned off the gas and only reopened it partly .
plumber Jim is offline   Reply With Quote
Old 11-01-2009, 11:51 PM   #5
Thanks for your help I cleaned out the pilot and it is staying lit Thanks again
More On This Topic
Okay, so the next step is to pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit... Read More »
Choosing a Fish Tank Heater
Choosing a Fish Tank Heater by Expert Village
Okay, besides filtration, your heat unit is most important, too and as with any other thing you purchase, you pretty much get what you pay for. This lower end type of heater will do the job, but it presents some problems in that circuitry is not as good... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
What is Boating Shorepower
What is Boating Shorepower by Expert Village
There are two panels. There's the panel for the battery and the panel for shore power. The twelve volt system, or the battery system, is the one down here. Even while you're plugged into shore power all these items on this panel only run if you have the... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 12:36 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 02:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 01:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 08:24 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
