Water Heater: Water In The Combustion Chamber - Leaking? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2012, 01:20 AM   #1
Water Heater: Water in the combustion chamber - leaking?
This is a 40-gallon natural gas water heater with power vent. Manufactured in 1994, installed in 1996, and well beyond the 10-year warranty.
On Sunday, I flushed the water heater (done annually a preventative maintenance). On Wednesday, the pilot was out. The pilot would light immediately and the burner would re-fire, but a little while later the pilot would go out again. This continued a few times over 2 days.
I'm now realizing that the reason the pilot is going out is due to water or very high moisture levels in the combustion chamber. There is some water visible on a few of the lower surfaces below the burner. Additionally, the lower rim is full of water.
I've confirmed there are no external leaking connections and there is absolutely no moisture problems visible anywhere externally. Is it a good assumption that this thing needs to be replaced, or am I overlooking something?
A few pictures are attached.
Thank you.
Water Heater: Water in the combustion chamber - leaking?-1.jpg   Water Heater: Water in the combustion chamber - leaking?-2.jpg   Water Heater: Water in the combustion chamber - leaking?-3.jpg
biglaz is offline   Reply With Quote
Old 12-28-2012, 05:01 AM   #2
DIY staff
Rewards Points: 7,174
Time to give that one the last rights----
It might be possible that the drain cock is leaking--that's the only thing you touched before you spotted water---not likely--but possible.
Old 12-28-2012, 06:37 AM   #3
Rewards Points: 582
well lets see 14-15 yrs old ..say good night and put that one to sleep...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (12-28-2012)
Old 12-28-2012, 06:42 AM   #4
Rewards Points: 1,216
Replace ASAP or be prepared to do a lot of cleanup.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
ben's plumbing (12-28-2012)
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 09:30 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 06:22 PM
