Water Heater Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2008, 03:52 PM   #1
water heater venting
can all gas water heaters be vented out a wall? or does it have to been a special heater. direct vent heater?
thanks
wazeaz is offline   Reply With Quote
Old 12-09-2008, 08:00 PM   #2
You need to check with the manufactures install and local codes for direct vent
NYCtinman is offline   Reply With Quote
Old 12-09-2008, 09:25 PM   #3
Different heaters require different venting. It is based on model and local codes.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-10-2008, 09:12 AM   #4
I agree with checking local Codes. The States I have worked in required the flue on gas heaters to "continually go upwards" until exiting the home. This meant that no horizontal runs of pipe could be used, only 45 degree turns. This applied to standard gas water heater flues.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-10-2008, 11:33 AM   #5
Registered User
Termite's Avatar
Upward flow is of course necessary. The vent is sized based on the appliance, the vent length, elbows, and other factors.
Local codes will dictate, and the manufacturer's installation instructions is more than likely what you'll be required to adhere to. I will tell you that it is rarely as simple as venting through a wall with a gas water heater. Most will require a roof vent termination in order to get airflow around the vent. Proximity to vertical surfaces is strictly limited by code, even on roof terminations. Proximity to doors, operable windows, inside corners, and grade can be a big issue.
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Venting a gas water heater renovation07 Plumbing 7 01-02-2008 09:46 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
