Old 08-13-2010, 09:13 PM   #1
Water Heater valve question
Hi,
I have a leaking shut off valve going into my hot water heater. It is not the drain valve, but the main cold water pipe going in. There is a shut off valve before it hits the tank and I just noticed it dripping. Really old. Just want to completely change it out. Changed many valves before but never going into the a water tank.
Questions, Do you have to drain the tank before replacing? Is it pressurized? Or can I just shut off the main water, cut the pipe, solder new valve and then turn the water back on.
Also what about gas? Can I just turn the gas off or do I need to fully disconnect it.
Lastly, for this application do you guys use a standard valve that keeps turning around or would one of those half turn ball valves be better?
thanks in advance.
bfan781 is offline   Reply With Quote
Old 08-13-2010, 10:11 PM   #2
Hello. To change the shut-valve for the water heater:
1. You do not have to drain the water from the tank.
2. The water coming in - into the water heater is under pressure.
You shut off the main for a while .
Some professionals do not turn the gas off because they feel
confident and to avoid lighting all the pilots for the entire house;
you can turn the gas off if you want to but you do not have to.
3. Many people use the standard valve the type that keeps
turning. There is very little room, so the ball valve with the
handle requires more room. Both work , but many people
put the old fashioned type.Best of luck
Gabriel24 is offline   Reply With Quote
Old 08-14-2010, 12:03 PM   #3
Turn the control knob of a gas water heater from run to pilot, or switch off the breaker for an electric water heater.
Open some hot and cold faucets upstairs. Drain several gallons of water from the water heater, or turn on both faucets of a laundry sink whose spout is lower than the top of the water heater. This will get rid of most of the water in the upstairs pipes that would otherwise fall down and out the pipe above the heater as soon as you cut it to replace the valve.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 08-14-2010, 08:53 PM   #4
Great thanks for the tips. Glad I don't have to fully drain it. Have all the stuff and I am going to tackle it in the morning. Have room for a ball valve so gonna use one of them. I like them a lot better seem like they last longer too.
I have a shut off valve for the gas right before it goes into the water heater can I just shut that off?
Old 08-14-2010, 09:21 PM   #5
Owner
LateralConcepts's Avatar
That's the safe way to go. You can do it live and should vapor lock, but if you have any bad cartridges you'd know it as soon as you cut into the copper.
After you've drained some water off, make sure to close all the faucets again.
Yes you can just shut off the gas valve nearest the heater, not necessary and you'll have to re-light it when you're done.
When you're finished installing the new ball valve; obviously, turn the water back on to the house (slowly), then open your new ball valve to re-fill the tank. Once you hear it stop filling, check for leaks, open all the faucets in the house until you bleed all the air out of the lines.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 08-15-2010, 11:45 AM   #6
Household Handyman
"bfan" is there a possibility that you may only need to tighten the packing gland around the stem to stop the leak? This may prevent you from having to go through the valve change procedure. Unlessen ya 'ont to. David
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 05:37 PM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 09:08 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
Water heater question devildog38 Plumbing 1 11-30-2008 04:13 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
