Water Heater To Tankless - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2012, 09:45 AM   #1
Rewards Points: 27
Water Heater to Tankless
Hello all,
We have been having some problems recently with our water heater. The water heater is going on 6 years old. We want to replace it with a tankless water heater. What should I know before getting one installed? Questions I have are::: Is the venting that I currently have acceptable? What kind of wall space is needed? What other questions should I be asking?
Any help on this would be greatly appreciated.
Have a great day
Bob
Pleesehelpme is offline   Reply With Quote
Old 08-04-2012, 10:30 AM   #2
Experienced
Jackofall1's Avatar
The biggest issue with this conversion is the size of the gas line, many tankless need a minimum of 3/4" line to them and many time the line coming into the home is large enough.
Mark
Old 08-04-2012, 10:39 AM   #3
Rewards Points: 27
Thank you for your reply. The gas line to our current water heater is 3/4". I would say we are good there.
Old 08-04-2012, 10:41 AM   #4
Rewards Points: 27
Also the main gas line coming in is 1" which recuces to 3/4 feeding to the rest of the appliances in our home.
Old 08-04-2012, 10:47 AM   #5
Experienced
Jackofall1's Avatar
You have to look at system total load in CFH to evaluate your main, ventiing is dependant on unit size.
Old 08-04-2012, 11:25 AM   #6
Rewards Points: 27
Is there some type of chart to get the proper size for my home?
Old 08-04-2012, 11:38 AM   #7
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Are you installing it yourself? The venting is an issue, most conventional water heaters vent into the chimney. I believe tankless vents straight through the wall. There are clear requirements in the installation manual. You should download it first, that would clear up any installation issues you may run across.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-04-2012, 12:17 PM   #8
Experienced
Jackofall1's Avatar
Yes if you search you will find many, and as Clutch said venting could be an issue, need to follow the manufacturers recommended method of installation.
Old 08-04-2012, 12:37 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Check out this thread
Journeyman Plumber
Old 08-04-2012, 12:46 PM   #10
Rewards Points: 27
I have read in each of the manufacturers manuals that we are trying to decide on that Category III venting is required.
Old 08-04-2012, 02:12 PM   #11
Rewards Points: 87
Tankless heaters are great (gas...not electric).
Don't undersize and buy one too small for your needs. See the manufacturer websites for proper sizing.
I have had a Tagaki tankless for 9 1/2 years and it has never had any problems even with 2 showers and washing machine drawing hot water at same time.
George6488 is offline   Reply With Quote
Old 08-04-2012, 02:14 PM   #12
Rewards Points: 27
Clutch, After reading some of the manuals the venting depends on the unit. The unit we are looking at has top venting which can be redirected in any direction either up through the roof or out the side of the house. We would just have to use the proper venting by code.
Old 08-04-2012, 02:15 PM   #13
Rewards Points: 87
I vented my heater direct thru the roof plus a fresh air vent was also needed for my unit. I believe that most manufacturers recommend independent venting and not shared.
Old 08-04-2012, 02:20 PM   #14
Rewards Points: 27
Yes I would be installing this myself. I would have to run this independently because the current venting is shared with the furnace and is not the proper venting for the tankless. I just want to be sure I have all T's crossed and my I's dotted.
Old 08-04-2012, 04:38 PM   #15
Rewards Points: 3,130
I would mount the unit on an outside wall and vent it through the wall. The vent pipe for the things is quite expensive. I installed my tankless myself, and that's what I did. You do, however, need to be mindful of required distances from windows, doors, and overhangs. These vary by location. There will also need to be a 120V outlet nearby for the control circuitry.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Tankless Water heater, worth it?? zacker HVAC 23 01-04-2012 12:34 PM
relocating water heater location going tankless bstinson Plumbing 2 12-07-2011 11:00 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 09:49 AM
