Water Heater T&P Plumbed To Cold Supply - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2011, 03:41 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Water heater T&P plumbed to cold supply
Helped a friend replace a water heater today. Located in a utility room under a raised beach house. Water heater is a 50 gallon low boy on a shelf raised about 4" above the floor. Connections about a foot below the ceiling. Cut the electric off, closed the gate valve and drained the heater. Cut the hot and cold connections off with a saws-all. T&P plumbing went back into the plywood covered wall, hit it with the saws-all. Water came out under full main pressure. Quickly shut off the supply to the house, no damage done. Finished removing the tank and opened the wall to investigate. The T&P drain was hard plumbed back into the cold water side.
Has anyone ever heard of such a configuration and what could be the possible reason to do this?
Installed the new tank and plumbed the T&P down to the floor. Capped the old pipe to the cold supply.
Coastal South Carolina
Old 05-20-2011, 06:59 PM   #2
Rewards Points: 352
And the plumber said "That's going to cost a little extra"
plumberinlaw is offline   Reply With Quote
Old 05-20-2011, 07:01 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
The things people do...
So, if the T&P blows, which faucet would turn itself on first?
Old 05-21-2011, 09:11 AM   #4
Rewards Points: 1,448
It was a wrong connection. There is no socially redeeming reason for doing this.
Old 05-21-2011, 09:38 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Whoever did that must never have seen a video of a water heater exploding, like the one that they had on "Mythbusters" one time. It shot way up in the air like a great tumbling rocket.
I've heard of people even plugging off the T&P too. KABOOM!
LOL
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-21-2011, 05:42 PM   #6
A "Handy Husband"
rjniles's Avatar
Further info on this:
This was not done by some hack DIY. There was a label on the tank of the plumbing company that did the work 17 years ago. And you could tell that no changes had been made since then. Called the tel #, apparently no longer in business - wonder why?.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
