-   -   Water heater T&P plumbed to cold supply (http://www.diychatroom.com/f7/water-heater-t-p-plumbed-cold-supply-105043/)
rjniles 05-20-2011 02:41 PM
Helped a friend replace a water heater today. Located in a utility room under a raised beach house. Water heater is a 50 gallon low boy on a shelf raised about 4" above the floor. Connections about a foot below the ceiling. Cut the electric off, closed the gate valve and drained the heater. Cut the hot and cold connections off with a saws-all. T&P plumbing went back into the plywood covered wall, hit it with the saws-all. Water came out under full main pressure. Quickly shut off the supply to the house, no damage done. Finished removing the tank and opened the wall to investigate. The T&P drain was hard plumbed back into the cold water side.:furious:
Has anyone ever heard of such a configuration and what could be the possible reason to do this?
Installed the new tank and plumbed the T&P down to the floor. Capped the old pipe to the cold supply.
plumberinlaw 05-20-2011 05:59 PM
And the plumber said "That's going to cost a little extra"
TheEplumber 05-20-2011 06:01 PM
199 Attachment(s)
The things people do...:no:
So, if the T&P blows, which faucet would turn itself on first?:huh:
AllanJ 05-21-2011 08:11 AM
It was a wrong connection. There is no socially redeeming reason for doing this.
Mike Swearingen 05-21-2011 08:38 AM
Whoever did that must never have seen a video of a water heater exploding, like the one that they had on "Mythbusters" one time. It shot way up in the air like a great tumbling rocket.
I've heard of people even plugging off the T&P too. KABOOM!
LOL
Mike
rjniles 05-21-2011 04:42 PM
Further info on this:
This was not done by some hack DIY. There was a label on the tank of the plumbing company that did the work 17 years ago. And you could tell that no changes had been made since then. Called the tel #, apparently no longer in business - wonder why?.
