Old 05-04-2012, 09:22 AM   #1
Water heater supply line leak
Installed a new water heater. The hot and cold lines had corrosion. I tried to clean them up and hoped for the best. They both have a slow leak. I want to replace them now, but it's not going to be as easy as it should be. The lines are copper flex lines with connectors on the water heater side only. The other side is soldered. Finding an exact replacement might be difficult. What would be the best method of repairing this? I have 3 ideas in my head.
dariusld is offline   Reply With Quote
Old 05-04-2012, 09:48 AM   #2
call me E
TheEplumber's Avatar
Replacement lines should be readily available. they're called nut x sweat flex lines and they should be replaced when installing a new heater. Cut the h & c lines behind the existing flex and solder on new ones or get the braided flex lines that have sharkbite fittings instead of sweat.
Old 05-04-2012, 10:15 AM   #3
Thank you for your response. With your help, I found this
My only concern with the Sharkbite is the small gap between the line and the heater. As it is, the flex line makes a sharp turn.
Old 05-04-2012, 12:01 PM   #4
Post a picture of what you have now. Someone may not have installed a Dilectric nipple on top of the heater, without it there's going to be corrision.
http://www.amazon.com/dp/B0006JLVEO/...SIN=B0006JLVEO
Old 05-04-2012, 01:32 PM   #5
call me E
These are available in different lengths. You should be able to get some that will fit. One end screws directly to the heater, the other solders to your pipe, but you prolly know that...
Old 05-04-2012, 02:27 PM   #6
raylo32's Avatar
Or cut the old flex coper lines off the H and C lines and sweat on 3/4" male adapters. Then you can get new copper flex ines or the braided steel covered flex lines with 3/4" female threaded connectors on both ends... and replace them again in the future when necessary without having to do any more soldering.
raylo32 is online now   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Water supply line blackhemi Plumbing 4 04-09-2011 09:18 PM
water line joint leak dtzulu Plumbing 4 05-14-2009 10:18 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
