Water Heater Suggestions - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2008, 01:41 AM   #1
Question
Hi I am new here and would like some help when it comes to picking a new water heater.
My wife and I will be moving into a new house soon and the water heater needs replacing. We will be renting out the basement of the house so the hot water will have to supply 4 adults and 1 child. We are considering a tankless water heater and would like to know if this is a good option or not?
wedge22 is offline   Reply With Quote
Old 05-26-2008, 01:53 AM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
While this might not give you the exact answer you're looking for, it's definitely info:
Advice - Tankless Water Heaters
angus242 is offline   Reply With Quote
Old 05-26-2008, 01:58 AM   #3
Thanks for the link, it looks like there can be issues with the gas pipes not being big enough going into the house. I think it would be easier to go with a 40 gallon heater as a replacement over the current 33 gallon one and try and find a highly efficient one.
Old 05-26-2008, 02:56 AM   #4
Rewards Points: 682
Tankless water heaters generally support a much smaller flow of hot water than a tank heater. You would have to adapt to that. With 4 adults that could get difficult.
I like tankless water heaters (more efficient use of energy) but at the present I cannot afford them, since they are also 3 or more times as expensive as regular tank water heater to buy and install.
darsunt is offline   Reply With Quote
Old 05-26-2008, 08:29 AM   #5
I have 3 adults and two kids in my home and took out our gas water heater and put in electric tank less heaters.First the cost of the heaters was was 1/3 less then replacing the gas heater second the cost of installation was about 20 dollars for some copper tubing third the savings on my gas bill was like 60 dollars a month and my electric only went up 3 to 5 dollars.Now if your thinking of going this way you don't want to buy from a box store to much mark up go on line and buy from the maker or on ebay and get a deal.You also might want to consider getting two since you will be renting the basement and put it on a separate line.The only problems we have had with our tank less heaters is we have well water and at first the sediment was cutting the flow but a filter system fixed that ,oh and to much hot water if thats a problem. This is just my opinion I am sure others have had good results and others have had bad
clasact is offline   Reply With Quote
Old 05-26-2008, 04:08 PM   #6
Thanks for the replies, it sounds like the tankless will be too costly and unable to provide water for the amount of users in the property.
Old 05-26-2008, 07:47 PM   #7
Rewards Points: 682
It does not make economic sense to buy a tankless water heater for most people at this time. But who knows about the future. In Europe and Asia, everyone uses tankless!
Old 05-26-2008, 07:56 PM   #8
I am originally from the UK and we had tankless there, its very popular. I think I will just go with a 40 gallon tank, anybody have any suggestions on a good gas model?
Old 05-26-2008, 08:06 PM   #9
Registered User
Termite's Avatar
AO Smith is very popular. I have a GE and have had excellent luck with it for 6 years now. Most name brands' units are comparable.
I'd suggest getting a 50 gallon gas unit. I wouldn't have an electric water heater on a bet.
Old 05-27-2008, 01:23 AM   #10
I will definately be going for a gas unit as the current one is gas. I think that if we were living in the house now I would get a tankless unit installed as I like the idea of it being energy efficient. For now a 50 gallon tanked water heater will have to do, now I just need to find a good cheap supplier in Canada.
Old 05-27-2008, 02:45 AM   #11
AZA
We'd be glad to help.....
I was told by 3 of my plumbing suppliers here in the Wash DC area that cold water heaters will be increasing in price by as much as 30%! That will be nationally. So act fast if you are going to get anything...
AZA is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
