03-29-2012, 09:20 AM
#16
Water heater solutions to get hot water in timely manner
I'm surprised nobody has mentioned the small point-of-use tankless heaters. The ones I'm familiar with are made by Eemax ( http://www.eemaxinc.com/). I don't know if they have gas models.
03-29-2012, 09:46 AM
#17
I never understood why "hot water" (from a water heater tank) is not good to drink considering that "cold water" sat in the water main or in a water cooler holding tank.
Have you ever observed the water company "flushing" water mains by opening hydrants one at a time? They do it only once a year if that, and quite a bit of "dirty" water comes out.
To get hot water fast with a minimum of adjusting of faucets you need to either install a third pipe with a recirculating pump, or install the water heater (or a water heater) close to where you use the hot water.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
03-29-2012, 01:34 PM
#18
Originally Posted by daluu
One of the other reasons to decide between the two is also, not just the cost factor (or in addition to it), how hard is it to feed a return line back to the heater. May be harder w/o an adequate crawl space, basement, or attic. Then perhaps patch through walls and even route outside the home as external piping...
Agree. Opening up walls, etc. to install a return line is a major concern and will be expensive.
As for water heater being filthy to drink, funny I haven't read any discussion addressing this:
Here's a bunch of youtube videos for your viewing enjoyment:
sediment in water heater
http://www.youtube.com/watch?v=mjWDyaQGDiY
clay mud in old water heater
http://www.youtube.com/watch?v=c4gUGV72L8w
why flush water heater at 1 min, 20 seconds.
http://www.youtube.com/watch?v=rmlLxEuhnGc
calcium and sediment accumulation in tank water heater
http://www.youtube.com/watch?v=A8Q1b...eature=related
hard water and scale in water heater
http://www.youtube.com/watch?v=qkAnB...eature=related
dirty water draining out of water heater at 1 min, 55 sec.
http://www.youtube.com/watch?v=QCNMT...eature=related
what's inside of your water heater
http://www.youtube.com/watch?v=ESP0x...eature=related
Importance of water heater flushing
http://www.youtube.com/watch?v=GWA5D...eature=related
what if you don't drink directly off the tap (whether recirc system to water line in place or not), but rather have a (lets say "good" for sake of arguement) water filter that the tap passes through before you drink or cook with it. In that case, the dirty water heater water then shouldn't be that bad if it's filtered. Granted one can say cold water is still cleaner, but the filter should mitigate some of the filth (chemicals, dirt, bacteria, lead).
Don't people use filters these days? Or most still go straight from tap?
Also, modern fridges, or good ones, allow you to patch a filter to the icemaker/water dispenser as well.
Installing filters would be one solution. Although we don't have a recirculation system, we don't drink water directly off the tap. I installed "smart water filters" under our kitchen sink and our refrigerator also has a water filter for the ice maker and water dispenser.
Best regards,
HRG
03-29-2012, 04:25 PM
#19
I just spent a year looking at how to solve this problem in my house. The shower in our house is 46 feet from the hot water tank, 30 feet in an unheated basement. Here is a quick comparison of the different options:
Central on-demand Water Heater (gas)
ProsMuch cheaper to operate than 40 Gal gas hot water tank
Direct venting instead of flue
Energy saving can pay back costs
ConsDoes not solve delay receiving hot water
Need to upgrade gas service which is more expensive than upgrading electrical
Very Expensive (install $1000 plus gas line)
Central on-demand Water Heater (Electric)
ProsCheaper than 40 Gal gas hot water tank
No venting
Need to upgrade electrical service (fortunately the electric company paid for this after the snow storm in October)
Very Expensive (install $1000)
Point of Use on-demand Water Heater (gas)
Pros Much cheaper to operate than 40 Gal gas hot water tank and central on-demand if limit to critical fixtures
Cons More expensive to set-up multiple point of use unit than one central unit
Must run gas pipes through house (Currently gas and flue in small area with short pipe lengths)
Luke warm water (same water volume with less BTU input = cooler output)
Expensive (install $1000 I don’t do gas)
Continuous Recirculating pump with thermostat and dedicated return line
ProsDelivers hot water fastest
Does not waste water
No hot water in cold water line
Cons Must have dedicated return line or cold line may contain excessive hot water
Expensive to run pump (electricity) and reheat returned water (gas)
Moderate ($600)
Timer based recirculating pump with thermostat and cold water return
ProsLess electricity than continuous running
Not unnecessarily heating water when typically not being used
Small amount of hot water enters cold water line
Cons
Contaminates from hot water tank enter cold water supply
Still uses power for pump (some pumps under sink, others near hot water tank)Slow hot water recovery off hours
Moderate ($400)
On-demand recirculating pumps using cold water return (push a button to activate)
ProsLess electricity than timer based pump
Remotes available so don’t have to be in bathroom while waiting for hot water.
ConsContaminates from hot water tank enter cold water supply
Still have to wait for hot water to arrive, but can be doing other things
Moderate ($400)
On-demand recirculating pumps using dedicated return (push a button to activate)
No hot water in the cold water line (hint: place return pipe connection just before the hot water tank to eliminate contamination of the cold water.
ConsAdditional plumbing required
Moderate ($600)
Passive recirculating using cold water return (sometimes called thermal cycle or gravity feed, hot water rises and cold water sinks)
ProsNo additional electricity/ no wiring
No additional plumbing
Cheapest ($200)
Fixture must be higher than the hot water tank (No traps in hot or cold water lines)
Does not work with on-demand water heaters
Passive recirculating using dedicated return
Cheap ($300)
Fixture must be higher than the hot water tank (No traps in hot or return lines)
After all the analysis I went with a passive system (NIBCO Just Right 4075) with a dedicated return line. Why?
· No additional power. I was not willing to trade convenience for electricity. There is some additional gas usage, but that has been offset with gains in efficiency elsewhere.
· No need to run the additional circuit to either the basement or bathroom. I still ended up running the additional circuit to bring the bathroom up to code.
· Since I was completely replacing the plumbing anyways and the hot water tank was in the basement, it was easy to add the return line and make sure the hot always flowed up and return always flowed down.
· NIBCO is a trusted brand. Some of the other systems I thought were over hyping themselves.
· NIBCO valve goes near the hot water tank, so the return line could connect to any fixture. Most systems have a valve or pump near the fixture, so you are limited to connecting to a sink where the valve is accessible per code. I really wanted the fast hot water for the shower which is 12 feet of pipe further away than the sink.
· The cost including the NIBCO valve and return line was under $100, not including labor. I also spent an extra $ 30 to run, but not plumb, an additional return line under the sink, just in case. If the theory doesn’t work in the real world, $130 was worth the experiment.
I suspect that the passive approach won’t work for you because it sounds like the water heater and the fixtures are on the same level. Passive works best when the water heater is in the basement and the fixtures are on the first or second floor. Also, if you have long runs of uninsulated pipes the heat loss may be so great that hot water will never reach the furthest fixture through normal thermal movement.
Reason: Added indentation
03-29-2012, 04:40 PM
#20
Thanks goosebarry, would like to hear updates from you on how that works out overtime. Yea, the passive system probably won't work for me, single story home, on slab foundation. And any dedicated return line would have to go through walls and maybe outdoor piping as the heater is out in the back of the house, rerouted from garage.
05-07-2012, 01:58 AM
#21
JOATMON
Sorry for digging this thread up....though it's not as old as some of the others I was searching....
I'm in the middle of a 2-story addition....part of the project involves moving my water heater from the front corner of the house to the back/side of the house...in real world terms...it means that hot water will be about 20' closer to the majority of items that use it...but it also means that the kitchen (front of the house) will now be about 30' (as the pipe fly's) from the water heater. Add to that the new upstairs bathroom....delay in getting hot water is going to be an issue......hence, I'm looking at hot water recirc systems.
I have ruled out the simpler system that uses the cold side as the return...when I want cold water...I want cold water....seems counter productive to have to waste water on the cold side while you wait for it to get cold. In other words, goose pretty much covered the issues....
So...it looks like I'll go with a pump (on a timer) with dedicated return line....
Hence...the question....does the return line need to be 1/2" or 3/4"? Any reason I can't use 1/4" or 3/8"? I realize that the pump would need to run a little longer to get the lines heated up....but, if I can use 1/4"...then it means I can use 1/4" tubing which comes in nice long rolls....which means less sweat connections....easy to route....etc.
Side note....everything is/will be insulated.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-07-2012, 09:39 PM
#22
Since this thread was dug up, just wanted to provide an update:
I've been using the cold water line recirculation method. The recirc line is connected in hallway bathroom, kitchen and master bath are a bit farther away from it. So hall bath is about midpoint you can say, not the furthest endpoint. I also have a water dispenser line connected to a filter in the kitchen for drinking water.
I observe the following so far:
* no "warm" water from cold water line in kitchen, particularly the water dispenser.
* as I recall minimal "warm" water at cold water line in master bath sink
* warm water @ hall bath sink where recirc line installed
* kitchen and master bath don't instantly get hot water, but come fairly quick compared to ~10 minutes before the install. more faster @ hall bath.
* electricity (for recirc pump) and gas (for water heater) didn't skyrocket even though I have pump set for two 3-hr windows in a day. May have been higher than w/o that installation, but seems reasonable to me with bill under $50, but we'll see going forward a few months more.
So I guess warm water issue for the cold water line for recirc method is more dependent on where you install the recirc line. Unless needed, perhaps best not to put at further endpoint, but maybe the midpoint, or wherever you can best tolerate warm water on cold water line.
05-07-2012, 09:44 PM
#23
Your thought certainly makes sense for simplicity and perhaps cost too. Waiting to hear from experts to chime in. But I think whatever issue you'd get would be with water flow/volume as you've now reduced the pipe size making system work harder to push water back via the recirc line. It could make things worse if you encounter water hammer or have high water pressure, also possible issues if it will be one long line of tubing w/o corner bends.
I wonder how long such tubing will hold up / last compared to copper pipes, etc.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
