Water Heater Siphoning? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2013, 10:30 AM   #1
Water heater siphoning?
Hello:
I recently drained my pipes to prepare for the winter. I closed the main, opened my sink faucets in the house then opened the hot/cold drain valves down in the build up to drain the pipes. The system drained for a few minutes then stopped. I then closed the sink faucets in house and returned to the build up to find the hot water drain valve flowing again and the cold not so. Did I somehow enable a siphon situation of the water heater? If so, any suggestions? I cannot figure out what is actually occurring pressure wise if this is the case.
Thank you for any assistance.
mdebarro is offline   Reply With Quote
Old 11-19-2013, 04:17 PM   #2
Not quite sure what it is your trying to do. Others will be along shortly with more advice.
Water heater and furnace should have their own shut off and drains.
Are you draining all your pipes for the winter and going to another location?
Is your main shut off a gate valve or ball valve? Please Post pic of it if not sure. If gate valve, it may not be shutting or opening all the way. Lot of problems with old gate valves. Just a thought.
jmon is online now   Reply With Quote
Old 11-19-2013, 05:40 PM   #3
Thanks jmon! I am winterizing my pipes when I leave for the week. Each of the hot and cold lines have a faucet at the lowest point to drain the pipes when the main is turned off and I open a few faucets in the house to indri dice air. The pipes drain, both hot and cold. What happened was when I shut off the indoor faucets in the bathroom and kitchen it seemed to cause the hot water to begin dumping out again like the pipes were full. The only place contributing is the water heater. What is odd is when the indoor sink valves were open the hot and cold pipes drained out then stopped. When I closed them the hot started draining again (cold did not).
I am wondering if a back pressure situation prevented the pipe from the water heater from siphoning when the indoor faucets were open.
Curious situation.
Old 11-19-2013, 07:08 PM   #4
IMO, If your only leaving for a week, just leave the heat on low, and set the water heater to vacation untill you get back. Why do all this just for a week?
If you did not turn off and drain your HWH, then it's possible you created some kind of siphon effect. IDK. Maybe others can give you some better advice. Sorry I couldn't be of more help to you.
Old 11-19-2013, 07:37 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If youre trying to winterize it for a long period of time Id use an air compressor to blow the lines out ,any water trapped in lines can freeze and cause issues.
Id also dump rv anti freeze down fixture traps.
If youre just leaving for a week Id just shut the main off at the meter and leave the heat set on 50 to keep it above freezing,If you dont trust your furnace thats a differant issue.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 11-19-2013, 07:56 PM   #6
We utilize the cabin on the weekends so it is standard protocol to drain the pipes up there even for a week. is a small place with just a fireplace and a single wall heater down stairs.
The issue concerning me is why the water heater seems to siphon. The tank must be venting through the cold inlet line to allow the siphoning to happen on the hot side and out the drain faucet. ??
The Following User Says Thank You to mdebarro For This Useful Post:
jmon (11-19-2013)
Old 11-19-2013, 08:01 PM   #7
plummen's Avatar
Yes its drawing air in from the cold side.
Just remember if its not blown out completely any water left in the system can freeze,same with water in fixture traps.
The Following User Says Thank You to plummen For This Useful Post:
jmon (11-19-2013)
Old 11-19-2013, 08:10 PM   #8
Thank you for helping me think through what is going on.
Old 11-19-2013, 08:19 PM   #9
Your welcome. Didn't realize it was a camp you were talking about. Thanks for explaining.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
