Water Heater Sediment - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2008, 05:28 PM   #1
Unhappy
Water heater sediment
I manage an apartment complex where the water provided is very hard 17.1 (ppm). The 100 gal. commercial gas water heaters are lasting less then a year, then must be replaced due to sediment build up. We have tryed frequent flushings, water softners and "zeta Rod" nothing seems to work, any suggestions?
Pete Moulton is offline   Reply With Quote
Old 11-18-2008, 07:54 PM   #2
Filter before each water heater. Will have to replace often but cheaper than replacing water heaters.
Also consider tankless water heater. No problems with sediment there.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-18-2008, 08:19 PM   #3
With a softener and possibly a filter ahead of the tank, it should take care of the problem, at least for more than a years use. With that hard of water and sediment, don't evn think about a tankless. Most manufacturers will state flat out that they will clog very quickly. The small tubing used in them is not tolerant of solids.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Hard Water or Water Heater Sediment ? sdcards Plumbing 6 08-20-2006 07:37 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
