Water Heater Rusty Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2012, 02:24 PM   #1
Water Heater rusty leak
I just noticed my 2 year old water heater has a slow rusty leak coming from behind the pressure relief valve. I called the GE help line and the guy said to remove the valve and put teflon tape on it but but couldn't explain why it was rusty. I'm wondering if there is more of a problem to it than that. I included a picture. I'd really appreciate any help.
JDJC is offline   Reply With Quote
Old 08-19-2012, 02:49 PM   #2
Rewards Points: 13,960
May have more to do with your water.
Ever notice rust stains in your toilet or tub?
Is it a steel or glass lined tank?
Do you have old steel supply lines?
Do you have a water softner?
Old 08-19-2012, 02:55 PM   #3
Rewards Points: 1,216
Make sure if you intend on removing the valve and repairing to get a full description of the procedure on this site. If not you may get burnt real bad.
COLDIRON is offline   Reply With Quote
Old 08-19-2012, 03:00 PM   #4
Thanks. I don't have any rust in the tubs or toilets. No water softener and the supply lines are copper. I'm not sure if its steel or glass lined.
Old 08-19-2012, 03:11 PM   #5
Right now the lining is the last thing you should be concerned with just keep it simple and stick with the valve leak worry about everything else later after the leak is repaired. Relax it looks like a minor repair at this time and if it's not you might get a new one under warranty.
Old 08-19-2012, 03:28 PM   #6
Thanks. I'll take care of the leak and keep an eye on it.
Old 08-19-2012, 06:54 PM   #7
Rewards Points: 582
there is a slow leak around pop off valve...its rusty because its iron around the opening and its rusting ....follow ge advice ...replace relief valve..double check for leaks...
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (08-20-2012)
Old 08-20-2012, 06:18 AM   #8
Thanks for the advice! Will do it today.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
