Water Heater Recirculator - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2008, 11:25 AM   #1
I have had a working hot water recirculator for over 7 years. No problems at all.
All at once the water was no longer "instant" hot at the faucets.
Thinking it was the recirculator, I replaced it with a new one. (TACO) (installed correctly). I can hear it come on.
My problem is that the water is still is not circulating.
I looked at the return pipe and can't find any damage or crimped bends.
Is it possble that where it enters the gas water heater, it could be stopped up?
Any thoughts or suggestions on what to do now?
Startfireman is offline   Reply With Quote
Old 04-17-2008, 07:44 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You sure the flow of the pump is towards the water heater?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-18-2008, 11:04 AM   #3
Absolutely
Old 04-18-2008, 11:35 AM   #4
Rewards Points: 1,156
Look for a valve turned off that shouldn't have been, or a bad check valve.
LawnGuyLandSparky is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
