Water Heater Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2011, 09:20 PM   #1
water heater question.
Is a captive air water tank the same as a thermal expansion tank?
John Harnar is offline   Reply With Quote
Old 03-11-2011, 01:55 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, but I think that the answer to your questions is no.
A thermal expansion tank goes near a water heater to absorb hot water expansion into supply lines.
A "captive air water tank" I believe would be a pressure tank such as at a pump that controls the cut-on/cut-off of the pump (air pressure in a bladder).
Mike
Mike Swearingen is offline   Reply With Quote
The Following User Says Thank You to Mike Swearingen For This Useful Post:
John Harnar (03-11-2011)
Old 03-11-2011, 08:00 AM   #3
I am installing a new water heater today and want to add a thermal expansion tank to the system. I got this captive air water tank at a sears -Hdw that is closing, thinking it is a thermal expansion tank. When I got home and looked at it I realized it is is not. However they seem to be the exact same thing, a pressurized tank with a bladder that absorb excess pressure. Am I wrong ? can they be used interchangably ?
John Harnar
Old 03-11-2011, 09:14 AM   #4
Rewards Points: 1,548
Subject to their capacities the two kinds of tanks will work interchangeably. An expansion tank is suggested (sometimes code-required) right at the water heater on the cold pipe after the cold inlet shutoff valve so it is not accidentally isolated from the water heater if the latter valve is shut off. The disadvantages of a large one is that additional bracing or guy wires are needed to support it and also the tank is more expensive. It should be above the water heater, not put on the floor.
The captive air/water tank is fairly large so pressure changes will be more gradual and the pump (well pump) does not go on and off very frequently for short periods when you are using the water.
The Following User Says Thank You to AllanJ For This Useful Post:
John Harnar (03-13-2011)
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Condensation on ceiling near water heater. EkS Plumbing 5 10-12-2010 10:48 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
