Water Heater Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2010, 06:09 PM   #1
Question
water heater question
I got a new water heater and installed it now there is constant running water in my guest bathtub, all the other facets don't leak. What is causing this to happen and how do I fix it ?????????????????
kyleea is offline   Reply With Quote
Old 09-10-2010, 07:28 PM   #2
duh who me
El Cheapo's Avatar
you loosened up rust in line some of it stuck in bathroom fixture that is running try shutting water on and off if that doest work remove stems clean out rust or change washers or rubber seats (delta style) while you have stems out if every thing fails call plumber
El Cheapo is offline   Reply With Quote
Tags
running water , water heater , water heater leak , won't stop leaking
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
