Water Heater Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2009, 09:16 AM   #1
water heater question
I am an electrical contractor, while on a call to check a water heater, I found that the cold and hot water connections were reversed. It has been in service like this for at least 7 years. I have never came across this before. Is this a problem? should it be corrected or left as is? Thank you for any advice on this matter.
dabutcher is offline   Reply With Quote
Old 12-02-2009, 12:16 PM   #2
ccarlisle's Avatar
Well, you don't need to be a genius to know that, in that case, there's probably inadequate hot water output for the size of the tank (maybe adequate for the residents, if they are low consumers of hot water) and that they're wasting money paying for hot water and getting warm water...thermostat may be adjusted upwards to compensate...!
My cold water comes in from the bottom; some electric heater have cold water come in at the top but the plastic tube delivers it down at the bottom. Hot water rises therefore in your case you are drawing water from the bottom and feeding cold water at the top...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-03-2009, 10:03 AM   #3
Most water heaters have a dip tube in the cold water inlet of the tank. The cold water is taken to the bottom of the tank and this "pushes" the hot water out the top. It could be that (for whatever reason) the installer switched the dip tube to the hot side. There is really no difference since the inlet and outlet are just connectors welded into the top of the tank. The exception would be if there were heat type backflow preventers in the unit. Hot water would be limited to less than 5 gallons if the dip tube was not in the cold water inlet.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 10:13 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
