Old 05-29-2009, 12:50 AM   #1
Unhappy Water Heater Question
New to the DIY. We flushed our electric water heater and replaced both elements and thermostats. We are refilling the tank and are not supposed to turn the power back on until is refilled. My question is: Should we be able hear the tank refilling? Upon initially starting to refill, we turned on another hot water valve... it sputtered but then started to run at a normal pressure. My mom is concerned because she can't hear it refilling, should we be able to hear it? Is there a way to test to make sure it is full, so we don't damge the new element?
DIYNewbi is offline   Reply With Quote
Old 05-29-2009, 03:12 AM   #2
Building codes guy, Mod
thekctermite's Avatar
If you can shut off the water supply to the heater you could open the valve near the bottom of the heater and see if you get a good amount of water coming out.
Water heaters fill pretty quietly.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 05-29-2009, 03:17 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Open the farthest hot water tub faucet (no aerator to clog) and run it until all of the air is out and it's running a full water flow. Then open all hot water faucets to remove the last of the air in the lines. You can't necessarily hear the tank filling, but you're right, fill it with water before turning on the power or you will fry the element(s).
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-29-2009, 09:20 AM   #4
Oh good, that eases my mind, we will try to drain it a little to test it out. thank you for the response.
Old 05-29-2009, 09:24 AM   #5
Thanks Mike-I opened all the hot water valves in the house and now all are running at a good pressure. I think we are good now, Thanks for the help.
Old 05-29-2009, 10:50 PM   #6
Originally Posted by thekctermite View Post
If you can shut off the water supply to the heater you could open the valve near the bottom of the heater and see if you get a good amount of water coming out. .
Psst! This is not a good test to prove that the tank is full enough to turn on the heat without damage.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
Old 05-30-2009, 01:33 AM   #7
Then offer something more useful. If you want to openly disagree with me that is fine but qualify your statement.
Old 05-30-2009, 12:01 PM   #8
(Then I would be parrotting someone else's response above.)
Old 05-30-2009, 04:41 PM   #9
Hallelujah, we have completed this fix. The water IS filling properly, and does fill very quietly and quickly. We actually had to drain it and refill it another two times because we had a small leak around the upper element. In turn we had to take the new element back to the store and exchange it, it was faulty. We have replaced the element and refilled again, no leaks...and we have now restored the hot water. I appreciate you all for your input and help. Thank you very much, WOO~HOO.
Erika
Tags
plumbing, question, water heater
More On This Topic
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
Choosing a Fish Tank Heater
Choosing a Fish Tank Heater by Expert Village
Okay, besides filtration, your heat unit is most important, too and as with any other thing you purchase, you pretty much get what you pay for. This lower end type of heater will do the job, but it presents some problems in that circuitry is not as good... Read More »
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 08:59 AM
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 12:57 PM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-23-2008 12:13 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 05:53 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 08:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
