Water Heater Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2012, 11:22 PM   #1
Chuck Kiser's Avatar
water heater question
OK, in the interest of 'Full Disclosure' I am a GC. My training is as a carpenter, but I did a 2 year plumbing apprenticeship about 25 years ago. Don't shoot me for a dumb question!
I helped a friend by fixing his Bradford White water heater. A 40 gallon natural gas unit. It turned out that the high temperature limit switch that is flush mounted to the combustion chamber access door was bad. I replaced it and everything is working as it should. So far, so good.
My dumb question is: what is it there for? Why monitor the heat in the combustion chamber? Won't the T-stat turn off the burner. Is it a redundant safety feature in case the T-stat fails? Do all water heaters have this feature, just mounted out of sight?
This is just to satisfy my personal curiosity.
TIA Guys.
Chuck Kiser is offline   Reply With Quote
Old 04-15-2012, 11:24 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
TIA Guys.
Ayuh,... Donno Chuck, but I'll bump this up, just to see an answer to the question....
I'd think it's a Safety feature, but don't know....
Bondo is online now   Reply With Quote
Old 04-15-2012, 10:18 PM   #3
Rewards Points: 582
TIA Guys.
by t stat i think you mean control valve...to answer your question...NO... safty switch monitors inside chamber for heat from blocked vent...t stat as you call it..measures inside tank..water temp...
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
