Water Heater PRV Valve Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2008, 01:21 PM   #16
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
depending on where you live, it may be OK to use CPVC for the relief line. Check with you local inspection department. If so, this makes it a lot easier to replace the T&P valve. This will come in handy if you decide to perform the recommended maintenance on your new heater. Most people don't but flushing your heater and checking the T&P annually can add years of safe operation to the life of your heater. Just plan on replacing the T&P valve at some point because if it is tested regularly it will eventually start to leak.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 08-24-2008, 07:08 PM   #17
Rewards Points: 150
one thing at a time here, its been 9 hours and no water anywhere, thats a record. As far as the prv line, can that be PVC?
econdave is offline   Reply With Quote
Old 08-24-2008, 09:53 PM   #18
mstplumber's Avatar
Rewards Points: 150
No, PVC isn't approved for that application in any code I am aware of. CPVC is rated for higher temperature and is approved in the International Plumbing Code.
Mstplumber
Old 08-27-2008, 05:13 AM   #19
Rewards Points: 150
2days go buy and no leak. Last night a puddle on top of water heater again. I believe it is dribbling out of the PRV. My expansion tank is at 90 PSI,
Old 08-27-2008, 06:18 PM   #20
Rewards Points: 1,596
Have you measured the water pressure at a hose bib somewhere (like the drain valve on the bottom of your water heater)? You can get one for like $15 at big box store. This will tell you if your system water pressure is too high. You may need a pressure reducing valve on the main line entering your home. Typically, you need less than 50-60 psi.
Your water pressure entering the home may be too high for the expansion tank to handle.
bob22 is offline   Reply With Quote
Old 09-02-2008, 07:01 AM   #21
mstplumber's Avatar
Rewards Points: 150
It is always a good idea to make sure the water pressure is not too high, but if the threaded joint at the T&P is done correctly (with pipe dope or teflon tape and tightened properly), it should not leak. Remember, the T&P valve is designed to allow wter out at pressures exceeding 150 psi. It really sounds like maybe a bad weld or fitting on the tank.
Mstplumber
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 06:22 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
