Water Heater On Preventive Maintenance? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2014, 10:28 AM   #1
Rewards Points: 95
Water Heater on Preventive Maintenance?
Everyone -- First, let me apologize if this issue has been addressed before.
I own a couple of rental properties and condos. Several times, I have had to replace (or have replaced) water heaters for renters. Does anyone have any advice on a schedule (or predictive formula) that can be used to estimate when a water heater should be changed before it breaks down? Or is such a thing really not possible to predict?
I have had both leaky heaters (usually on older units, but also on units well inside their warranties) and no-heat situations (burners of electric elements that fail which usually do not require the entire heater to be replaced.)
I have had water heaters fail within a month of being installed -- even though they are "12 year" or "9 year" heaters. I also have a couple of heaters that are at least 40 years old and are still plugging away.
Any advice would be appreciated.
Perry401 is offline   Reply With Quote
Old 08-20-2014, 10:45 AM   #2
Rewards Points: 215
I know of no way after having similar issues and speaking with plumbers.
Some items I look at though are
-any water under the heater is not good and could mean imiment failure.. should always have a pan or some way for the water to get to a sump in case it happens.
- I was told to open the valve at the bottom of the heater a few times /year and drain a bucket or 2 of water ... helps clear sediment.
- Also, the pressure relieve valve at the top should be changed every 5 years whether it's leaking or not. this is an easy 5 minute replacement job, and the valve is around $15.00.
Other than that... if no heat even though unit running is something for a plumber to look at.
davemax is offline   Reply With Quote
Old 08-20-2014, 11:58 AM   #3
Rewards Points: 744
Replace the sacrificial anode and drain the tank (completely) once per year.
When the anode is depleted, the tank walls will begin to corrode. If you keep a good anode in, the tank should last a long time.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
jmon (08-20-2014)
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 05:44 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
