-   -   Water Heater Pressure relief valve problem (http://www.diychatroom.com/f7/water-heater-pressure-relief-valve-problem-35859/)
joedadog 01-13-2009 09:08 PM
I have a rental house with a water heater that seems to leak out the pressure relief valve. I noticed a damp area that was dirty and molding on the floor below the relief tube. It seems dry but has been there for some time, it is not leaking constantly. Can someone tell me what causes that top happen. The water heater has to be at least seven years old. Do I have to replace the valve?
metx 01-14-2009 08:06 AM
the relief valve leaks because of to much pressure or faulty valve
Shoogy 01-14-2009 09:06 AM
more than likely the T&P valve has gone bad and needs to be replaced this is a common issue and should be handled by a proffessional as an improperl installed t&P valve can cause yur water heater to explode.
Reilley 01-14-2009 11:53 AM
As seen on MythBusters, it can fly hundreds of feet into the air after shooting right up through your roof. Pretty scarey...
WaldenL 01-14-2009 12:34 PM
You can track that down on YouTube, actually quite scarey, however, I'm not sure that you'd need a professionaly to install a TPV. IIRC, on my water heater at least it's a simple screw-in valve on the side of the heater. I'd think it's a case of unscrew, tape, rescrew. Hardly professional territory.
-Walden
Reilley 01-14-2009 01:58 PM
-Walden
I concur... just need to find the proper procedure. Probably goes something like this:
-kill the power
-kill the water supply
-drain the tank (or just relieve the valve until it stops relieving?)
-unscrew
-tape new valve
-screw in
-restore water
-restore power
Confirm this first.
