Water Heater Pressure Relief Valve Leaking. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2010, 07:32 PM   #1
the pressure relief valve on my hot water heater started leaking after i tested it, a very slow drip. after reading up on them i replaced it last weekend, but it is still leaking. it only seems to leak when we take showers, and its a very small amount of water, any ideas? is my water tank going to explode?
thanks.
merton is offline   Reply With Quote
Old 03-29-2010, 08:06 AM   #2
Do you have an expansion tank on the system? Its possible the bladder inside has blown and it needs to be replaced. The pressure build up won't have anywhere to go which can then trip the T&P valve on the heater.
There should be an air valve on the expansion tank (like a bike tire valve). Press it briefly. If water comes out, the tank's bladder has blown and it needs replacement.
If air comes out, its fine.
You can also check out: http://www.terrylove.com/forums/forum.php
I've had real good luck with that forum for plumbing issues!
D-2.5-GT is offline   Reply With Quote
Old 03-29-2010, 08:37 PM   #3
Wen the temp. is set to high sometimes the relief valve leak set it about 75%
frankiepr1964 is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
water heater PRV valve leaking econdave Plumbing 20 09-02-2008 08:01 AM
New Water Heater, worse pressure Repoman75 Plumbing 6 04-16-2005 12:30 AM
