Water Heater Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2011, 09:58 AM   #1
Ok,
We are fixing up a house that was stripped (foreclosure) and will be reinstalling the water heater. The water is supplied by a well. I have not really had a chance to get into the plumbing (we will be closing on the house in a few days).
But I was wondering about the stub outs where the water heater was.
Here are the photos:
There are three pipes coming out of the wall above where it appears the water heater was as what looks to be a drain line down at the floor. There also appears to be a copper ground wire coming out with the wiring for the heater where the left hand pipe is( I will be rerouting the wiring!).
So I am a bit puzzled why there are three pipes for the water heater. Any ideas how this was originally set up?
Tom
Tabman is offline   Reply With Quote
Old 12-21-2011, 11:11 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 816
It might have had a hot water circulation system.....if it is a big house....you would want it.
Was it the prev owners who stripped it or did someone break in and strip out everything?
Old 12-21-2011, 11:23 AM   #3
ddawg16,
Thanks, I didn't think of a hot water recirculating system. It's not a big house, but one bathroom is a fair distance from the heater. I will take a look and see if there is a bypass valve mounted in that bathroom.
Not sure who stripped the house, I suspect the last owner or tenants since there is no evidence of a break in. It's funny, they took the air handler for the AC / heat from inside the house, but left the condenser mounted outside.
Tom
Old 12-21-2011, 01:33 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Originally Posted by Tabman View Post
ddawg16,
Tom
Ayuh,... Tom,..?? Tabman,..?? Tabman Tom,..??
I know you,... How ya doin' Bud,..??
Boy they really trashed the place, eh,..??
Sounds like they had No talent, 'n especially, No Tools...
Good luck with yer new house,.....
Old 12-21-2011, 01:59 PM   #5
the one in the middle could have been for the relief valve to connect to. thats the way they did them when i was in fla. do you know where the water main enters the house? do you have a meter pit? I have also seen places where the 3rd line was the main coming into the house but not as often as the relief valve in the middle. the drain at the floor was probably for the pan under the water heater.
Old 12-21-2011, 03:00 PM   #6
biggles's Avatar
Hot on the left...Cold on the right...middle is RELIEF from the HWH tank and tube drain the tank sits in the controls for the heatr face out so when you slide one in it is ptreety staright foward..find out where that middle vents off to has to thread into the unit mounted relief with the heater...need a disconnect to run that 208V into and mount it off to the side..then ou to the heater for code..
Old 12-21-2011, 03:01 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I would open up the wall around the pipes and the electric cable. You will probably have to install a junction box to repair the electric. Replace with a plywood panel when you are done. The ground wire could be the bond to the electrical panel.
To identify pipes:
Turn the water supply on for a second to identify the cold supply.
Get an air compressor and blow into the pipes with a hot water faucet open to identify the hot. The third pipe could be the drain for the T/P valve or it could be the cold supply to the rest of the hose. A few tries with the compressor will tell.
Coastal South Carolina
Old 12-21-2011, 04:06 PM   #8
Hey Bondo!
Fancy meeting you here! It's a little different than the boating forums!
Oh yeah they trashed the place, but got a good deal and it is a very cool place. Lots of land and plenty of work to keep me busy when I'm not being Tabman on the internet!
Old 12-21-2011, 04:14 PM   #9
OK, the line for the relief makes sense. There is no meter pit since it is a well. Yes, I will be taking the wall down, I don't know that a junction box will be need for the power supply. The main breaker box is just to the right out of the picture, so it will be easy to see what's up once I get into it.
Thanks for all the help guys. We should close any day and I am getting a head start on the things I will need to tackle first to set up camp and work on the rest.
This place is great and I am sure I will be asking plenty more questions.
Tom
Old 12-21-2011, 04:52 PM   #10
biggles's Avatar
just a thought on that disconnect if its that close off the CB panel
Old 12-21-2011, 07:53 PM   #11
Bondo's Avatar
Rewards Points: 338
Tom
Ayuh,.... Beautiful lookin' place Tom,... Lotsa elbow room, I like that...
Looks like the bushes in front of the place are nearly trees now,...
Beat 'em back away for the house,...
Them branches will tear the place apart....
Good luck, 'n have Fun with it....
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Smelly brown water from water heater timthetoolman Plumbing 2 05-19-2011 10:32 AM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
