Old 10-24-2009, 05:45 PM   #16
Good luck.
plumber Jim is offline   Reply With Quote
Old 10-24-2009, 09:45 PM   #17
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation No hot water !
CHECK THE BRADFORD WHITE WEB SITE FOR A LOCAL " SERVICE AGENT "
THEY WOULD HAVE THE CORRECT PART IN STOCK AND CAN DIAGNOSE TO MAKE
SURE THEY ARE REPLACING THE RIGHT DEFECTIVE PART !
ALL YOU WOULD PAY IS WHATEVER LABOR CHARGE AND COULD GET IT FIXED
RIGHT AWAY INSTEAD OF WAITING FOR B/W TO SHIP A PART THAT "MAY"
OR MAYNOT BE THE CORRECT ONE TO FIX YOUR PROBLEM !
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
We did here in our houses. We have the good insulation but it was not good enough for me. So when we got all these packages from the company's with all these Styrofoam chips in there, we used these chips and put them on top of the ceiling and add to the... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 07:58 PM
Water Heater tsmith Plumbing 10 12-01-2008 08:24 PM
Tankless Hot Water Heater - One Fauset Does Not Have Hot Water? vsheetz Plumbing 1 10-29-2008 01:18 AM
water pooling ontop of water heater nannerkrns Plumbing 2 09-24-2008 12:04 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
