Old 10-24-2009, 04:49 PM   #1
Default Water heater pilot will not stay lit
My pilot went out last night. I can get it to light but it will not stay that way. I installed a new t-coupler and the same remains true. It lights but after a minute when I release the gas, it goes out again. I then took off the other lines and checked for clogs and they are fine. I am lost. Any help would be appreciated.
Mack_mann is offline   Reply With Quote
Old 10-24-2009, 04:51 PM   #2
You may have a bad gas control valve.
plumber Jim is offline   Reply With Quote
Old 10-24-2009, 04:54 PM   #3
Is there any way to check that?
Old 10-24-2009, 04:59 PM   #4
Yes, but you would need to know how which is better done by a pro to be sure. Is it the older style heater which has an open combustion chamber? or the new sealed ones which has a door with a couple of nuts on it?
Old 10-24-2009, 05:02 PM   #5
It's a newer unit installed 3 yrs ago.
Old 10-24-2009, 05:06 PM   #6
What brand?
Old 10-24-2009, 05:10 PM   #7
Bradford
Old 10-24-2009, 05:11 PM   #8
there is a reset button did you press it? its on the combustion chamber door.
Old 10-24-2009, 05:12 PM   #9
I haven't seen it... More info on the reset position please...
Old 10-24-2009, 05:15 PM   #10
can you post a picture of the area of the heater where the thermocouple goes into the heater?
Old 10-24-2009, 05:17 PM   #11
I found it.....Thanks! I will see if it's popped and let you know!
Old 10-24-2009, 05:18 PM   #12
Does the door look like this?
http://www.terrylove.com/images/wp/b...ersion_kit.jpg
The little white button on the right may need to be pressed in. its the center tiny button. if it clicks then it was tripped. if not then it may be the control valve.
Old 10-24-2009, 05:24 PM   #13
You had me excired but it wasn't the reset. It must be the valve. Thanks for the input!
Old 10-24-2009, 05:27 PM   #14
Did you check the bradfordwhite website to see if it was under warranty? if its only a couple years old it should be.
Old 10-24-2009, 05:42 PM   #15
It is under warranty. I hope they will send it to me without any issues.
More On This Topic
Okay, so the next step is to pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit... Read More »
If you need a crash course (no pun intended) in chatting it up like a pilot, you will need a little confidence, a little knowledge of aviation and the ability to convey information in a clear, concise manner. Look at these steps and before you know it... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Hello, my name is Matt Cail on behalf of expertvillage.com, I'm here today to talk about trick or treating safety. Another tip is to stay at the houses that have their lights on. Now, Halloween and all the various fun associated with it is often times... Read More »
So what you see here is our water heater. And this water heater is a big one, because we want to store as much water as possible when we get the hot water from the sun. If you would use only a 10 gallon or a 20 gallon water heater, and we take a shower... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 07:58 PM
Water Heater tsmith Plumbing 10 12-01-2008 08:24 PM
Tankless Hot Water Heater - One Fauset Does Not Have Hot Water? vsheetz Plumbing 1 10-29-2008 01:18 AM
water pooling ontop of water heater nannerkrns Plumbing 2 09-24-2008 12:04 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
