Water Heater Pilot Light - Please Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2010, 06:47 PM   #1
I have a whirlpool bfg water heater. 4 days ago the pilot light went out and would not stay lit. By following the troubleshooting guide I determined the thermocouple needed changed. This did not work.
I have now replaced the Pilot Door Assembly, Thermocouple, and the Gas Valve / Thermostat. After replacing the valve/thermostat the pilot light stayed on and the heater appeared to be operating normally.
I now have a full tank of scalding hot water so I went up to turn down the thermostat a bit and noticed the pilot light is out again and will not stay lit...
Can anyone help with this?
mwshockley is offline   Reply With Quote
Old 01-24-2010, 08:08 PM   #2
Rewards Points: 1,446
Pilot light nozzle clogged a little so pilit light is too small to keep the thermocouple hot?
Pilot light not aimed at the thermocouple to keep it hot?
Don't forget, you need to hold the button down for almots 60 seconds to get the thermocoouple hot enough to keep the pilot light lit.
AllanJ is online now   Reply With Quote
Old 01-24-2010, 11:00 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
check gas supply to pilot
plummen is offline   Reply With Quote
Old 01-25-2010, 07:42 AM   #4
Back drafts blowing it out.
SULTINI is offline   Reply With Quote
Old 01-25-2010, 08:23 AM   #5
plummen's Avatar
i thought about a draft also but it sounded like he cant even get it to stay lit when he lets off the button
Old 01-25-2010, 04:15 PM   #6
Licensed Master Plumber
It's probably the thermocouple again but it could be other things as well. take a look at this site.
http://www.consumeraffairs.com/homeo...r_heaters.html
These Water heaters have been a service nightmare since the day they rolled off the assembly line.
It's probably out of warranty yes? and I hate to recommend this because you probably have a lot of money already sunk into this pig but your best bet is to rip the POS out and replace it with an AO Smith
NHMaster is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
brand new Hot water heater won't stay lit r386 Plumbing 4 08-23-2009 09:31 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
