Water Heater Pilot Light Is Lit, But Burner Won't Light - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2013, 11:22 PM   #1
Water heater pilot light is lit, but burner won't light
I have a 1 yr old A O Smith Gnr50-200. Water heater. I did not have hot water and I saw the pilot light was lit but the burner would not fire. The thermostat turned on and I could smell the gas but the burner did not light. I relit the pilot and the burner turned on. 3 days later no hot water again. Same thing relit pilot and burner fired up. Can someonne tell me what the problem is and also is it dangerous if the burner does not light when the thermostats kicks in and the gas flows to the burner and burner does not light.
jawest is offline   Reply With Quote
Old 01-18-2013, 09:13 AM   #2
Roofmaster
Rewards Points: 2,210
This does not make any sense. You have fire, you have fuel. I would suspect lack of draft, No Oxygen. Is your flue blocked off with a birds nest, or some other obstruction? Do you have an exhaust fan running in the house pulling air back down the flue?
Since this is a stand alone pilot, get a flashlight. Crack a nearby window. Kill house power, and turn up the stat with the pilot on. See if she lights off.
water heater pilot goes out Nick1 Plumbing 5 07-03-2012 05:46 PM
Help! Water Heater Pilot Light chris77535 Plumbing 5 06-19-2012 01:06 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Gas Water Heater w/ Electric ignition - no pilot Sparkus Plumbing 0 12-24-2011 05:10 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
