Water Heater Overflow Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2012, 03:49 PM   #1
D23
Water heater overflow leaking
I noticed a small drip coming out of the overflow pipe. Is this a concern? It is an electric water heater and is approximately 12 years old. The unit seems to be working ok otherwise.
D23 is offline   Reply With Quote
Old 03-31-2012, 06:02 PM   #2
Rewards Points: 12,858
Keep in mind that heater is behind the expected life span.
Try flipping up the lever and poping it right back down. That may reseat it.
If it's still leaking check the water temp. it should not be above 120 deg.
Still leaking, just change it.
Never ever cap it off!!
Old 03-31-2012, 06:47 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If it's still leaking, check the system pressure. . . . .
You may have a failed pressure regulator or expansion tank.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
VIPlumber (03-31-2012)
Old 04-01-2012, 12:59 PM   #4
seansy59's Avatar
Rewards Points: 258
A leak is bad. That means too much pressure is building up= faulty water heater. You may just want to replace it.....
seansy59 is offline   Reply With Quote
Old 04-01-2012, 02:16 PM   #5
Rewards Points: 1,418
Replace the temperature/pressure relief valve. Also install an expansion tank if not already, or repressurize the one already there.
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Water heater is leaking from the top lmlboone Plumbing 12 10-01-2008 04:18 PM
