Water Heater Not Working - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2012, 12:20 PM   #1
mathman32's Avatar
Water heater not working
Hey,
I have a water heater that is not heating water. I changed the heating element and refilled the tank, but I still do not get hot water. Any ideas?
mathman32 is offline   Reply With Quote
Old 06-04-2012, 12:39 PM   #2
Rewards Points: 6,652
Is this a gas or electric appliance? What do you mean by "refilled tank"?
Old 06-04-2012, 12:47 PM   #3
mathman32's Avatar
Electric. I refilled the tank meaning I had to drain it to get the heating element out. After replacing the element, I had to refill the tank.
Old 06-04-2012, 01:29 PM   #4
Rewards Points: 252
http://waterheatertimer.org/How-to-t...er-heater.html
shazapple is offline   Reply With Quote
Old 06-04-2012, 04:29 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
Sorry but gotta ask. Did you remember to turn the circuit breaker to the heater back on? When you say element (singular), did you replace the lower or upper element?
If the upper element is bad, water will not be heated even if the lower element is good. Aside from a wiring error, the upper thermostat contact that applies power to the upper element could not be making good contact.
Shazapple, nice link BTW.
HRG
Homerepairguy is offline   Reply With Quote
Old 06-04-2012, 08:25 PM   #6
mathman32's Avatar
I did turn the power back on.
There is a red reset button that I am going to push and see where that takes me. This unit does not have an upper element. There is just one and it is in the lower slot.
Old 06-06-2012, 04:31 AM   #7
Rewards Points: 998
What's the gallon capacity of the water heater?
BTW, did the red reset button fix the problem?
HRG
Old 06-06-2012, 09:10 AM   #8
mathman32's Avatar
It looks like the problem has been fixed. I didn't have to hit the red button.....just had to be more patient. Thank you all for your help with this!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 05:23 PM
low pressure after hot water heater replacement tuffluck Plumbing 4 06-07-2011 03:14 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
