-   -   Water heater not working (http://www.diychatroom.com/f7/water-heater-not-working-145948/)
mathman32 06-04-2012 01:20 PM
Hey,
I have a water heater that is not heating water. I changed the heating element and refilled the tank, but I still do not get hot water. Any ideas?
gregzoll 06-04-2012 01:39 PM
Is this a gas or electric appliance? What do you mean by "refilled tank"?
mathman32 06-04-2012 01:47 PM
Electric. I refilled the tank meaning I had to drain it to get the heating element out. After replacing the element, I had to refill the tank.
shazapple 06-04-2012 02:29 PM
http://waterheatertimer.org/How-to-t...er-heater.html
Homerepairguy 06-04-2012 05:29 PM
Sorry but gotta ask. Did you remember to turn the circuit breaker to the heater back on? When you say element (singular), did you replace the lower or upper element?
If the upper element is bad, water will not be heated even if the lower element is good. Aside from a wiring error, the upper thermostat contact that applies power to the upper element could not be making good contact.
Shazapple, nice link BTW.
HRG
mathman32 06-04-2012 09:25 PM
I did turn the power back on. :)
There is a red reset button that I am going to push and see where that takes me. This unit does not have an upper element. There is just one and it is in the lower slot.
Homerepairguy 06-06-2012 05:31 AM
What's the gallon capacity of the water heater?
BTW, did the red reset button fix the problem?
HRG
mathman32 06-06-2012 10:10 AM
It looks like the problem has been fixed. I didn't have to hit the red button.....just had to be more patient. Thank you all for your help with this!
