Water Heater Noises - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2009, 12:13 AM   #1
concretemasonry's Avatar
Rewards Points: 2,570
Water heater noises
I have gas fired 40 gallon A.O. Smith water heater (Model KGL 40-870) that has some pulsating or rumbling noises at times.
A know how dangerous a water heater can be (I don't want to wake up and find it in a nearby tree since the current altitude record is over 300'). When I hear the noise, I feel the vent stack and it it is not hot, but cool or warm, but the burner does not seem to be on. I have no idea of the age, but the serial number is AD81-35-45-870. Could it possibly be a 1981 heater?
It was there when I bought the townhouse. I last drained it 1 to 2 years ago (a little late as usual).
I shut it down to pilot just in case.
Any ideas?
If it is dead, I will just call a plumber immediately and get it replaced, but I need some thoughts from those that know more than me.
Thanx in advance.
Dick
concretemasonry is online now   Reply With Quote
Old 10-16-2009, 07:02 AM   #2
If it has a working T&P valve on the side(or top), there is little need to worry about it lifting off. That noise is usually due to mineral/debris buildup in the bottom. If you have silty or hard water it should be flushed several times a year. Since that was not done, I suspect what is there is there to stay. Basic water heater tanks rarely live to 20(8-14 is normal), so I doubt it could be '81. At this point flushing might do more damage than leaving it alone, although the efficiency is probably considerably reduced. Time to consider a replacement.
Old 10-16-2009, 03:59 PM   #3
Water heater noises
Everything done by 12:00 noon today.
The 28 year old beast (water heater) is out and replaced with the same brand since the original lasted 28 years. I assume the contractor will be able to get rid of it as well as he clean the rust deposits he old heater left in the driveway.
Dick
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 06:27 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
