Old 03-16-2008, 09:15 AM   #1
break-it-yourselfer
Water Heater Noise
I noticed my Gas Hot Water Heater makes a "clang" just after it finishes heating up.
Anything to fix?
DDASH is offline   Reply With Quote
Old 03-16-2008, 10:42 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Water Heater Noise
Try draining and flushing the tank out.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-16-2008, 12:58 PM   #3
Water Heater Noise
Does it have an adjustable damper in the gas exhaust (vent) line? If so, it may be loose and is "slamming" shut when the burner shuts off.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-18-2008, 04:04 AM   #4
Water Heater Noise
Often times there is a baffle in the flu that expand when wh is heating sometimes it will make a popping noise as its expanding, nothing to worry about. Could be minerals in bottom of heater.
shawnidaho is offline   Reply With Quote
water heater noise boman47k Plumbing 5 11-28-2007 07:31 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Booming noise in water heater pjpjpjpj Plumbing 1 01-31-2007 03:03 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
