Water Heater With A Mystery Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2012, 05:07 PM   #16
Rewards Points: 582
Originally Posted by Curb71 View Post
not sure if I understand correctly. the drain pan takes a few hours to fill up. somewhere between 2 and 12 I'd guess. The supply lines at the top of the tank are dry.
if the tank is thermally expanding it has to be leaking at the point of expanison....somewhere....not sure why tpr valve is not reacting ...you almost have to set up a video to see when it leaks....sure you checked all fitting good....
Old 08-05-2012, 05:32 PM   #17
lol. a video is a good idea. yeah I've checked everything over and over. got about 3 gallons of water in the bucket now that I've soaked out of the pan over the last day or so.
if thermal expansion was causing the water it would come out of the t&p drain line right? so weird that it's not.
I guess I gotta hire a plumber and see if they can figure something out.
Curb71 is offline   Reply With Quote
Old 08-06-2012, 12:58 PM   #18
Chicago, IL
Michael Thomas's Avatar
How old is the tank? More than a few years, and it's likely more cost effective to just replace it.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-06-2012, 08:44 PM   #19
I had a plumber out today. He noticed almost right away how the evap coil condensate line was tied into the water heater drain pan line and the line was stopped up from debris from the evap coil condensation. cut the pvc line open and cleared it out with a shop vac and sucked the water out of the pan too. I never thought the one place I thought where the water was draining from, was actually the place that the water was coming from, backing up back into the water heater drain pan.
The Following 3 Users Say Thank You to Curb71 For This Useful Post:
ben's plumbing (08-06-2012), Michael Thomas (08-07-2012), TheEplumber (08-06-2012)
Old 08-06-2012, 10:12 PM   #20
Plumber
TheEplumber's Avatar
Rewards Points: 682
Must be why my inspector wont let us tie into pan drains
The Following User Says Thank You to TheEplumber For This Useful Post:
Curb71 (08-07-2012)
Old 08-07-2012, 03:07 AM   #21
That's exactly what my plumber said too! Lol
Old 08-07-2012, 06:09 PM   #22
Rewards Points: 582
no no here also...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Curb71 (08-07-2012)
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Water Heater leak help needed :/ bluecifer Plumbing 9 12-17-2008 11:05 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
