Water Heater - Leaving Home Unattended For Two Months - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2010, 01:58 PM   #1
Water heater - leaving home unattended for two months
Hi
i want to leave my home for several months next spring. I will maintain interior temp around 62 and have somebody make weekly checks. I wanted to know the best way to set my domestic hot water heaters. I intended to shut the water feed lines, turn down the temperature settings and leave one hot faucet turned on. The idea of leaving the one faucet open is that it would allow for expansion and contraction of the water in the tank as the heater goes off and on (normally, this would be done by forcing water back to the feed line, afaik. I don't want to turn the heaters off completely, because somebody else is going to be using my home for several days before i return, and i want to simplify their task when they first come in - so i dont want them to have to reignite the burner.
ideas?
bruce_hyman is offline   Reply With Quote
Old 10-16-2010, 06:19 PM   #2
Rewards Points: 150
Turn your main water off and turn the water heater to pilot, you don't need to leave anything turned on, whoever comes in only has to turn the main valve back on and water heater to on.
braindead is offline   Reply With Quote
The Following User Says Thank You to braindead For This Useful Post:
bruce_hyman (10-16-2010)
Old 10-16-2010, 10:12 PM   #3
makes sense. pilot would be low enough theat input to the tank that i shouldnt have to worry about expansion/contraction.
Old 10-16-2010, 10:14 PM   #4
Rewards Points: 50
Also check your home insurance.Some companies require more frequent visits to a vacant home.Daily is a better idea than weekly.
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
Old 10-16-2010, 10:33 PM   #5
i will get the next door neighbor to look in. thanks!
Old 10-16-2010, 11:37 PM   #6
Why not just turn the pilot off? Why even keep the pilot lit? I have a second home that I turn it completely off every winter and drain it. Why waste the gas?
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 10-17-2010, 09:20 AM   #7
Rewards Points: 1,548
To make it easier for someone who is going to stay overnight as opposed to just walk through the house and check it. Now if he accidentally turns the knob from Pilot to Off instead of Run then he will have to get down on his knees and relight the pilot.
To make absolutely sure that the tank is full of water first, a hot water faucet should be running before the heater is restarted.
Old 10-17-2010, 12:45 PM   #8
good ideas. i *do* need to leave the house water on, because the weekly visitor will be watering the plants. thanks again.
Old 10-19-2010, 01:48 AM   #9
sylle1
Send a message via AIM to shirley6616
What if your home has 2 water tanks & home is completely electric (no gas, no Propane & you will be gone several months)?
shirley6616 is offline   Reply With Quote
Old 10-19-2010, 06:33 AM   #10
well, i have two gas hw heaters. in any event, i think the goal is to not allow the heater tank to be in a "lock" mode, and also - if it leaks - to not have an unlimited possible flow of water. so i'd shut either the house feed, or the hw inlet feeds, shut them down (electric) or pilot (gas), and leave a hw and a cw faucet partly open to allow the hw heater to not go into vacuum as it cools down. just mho. reverse on returning to the house.
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
