Water Heater Leaking At Top Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2007, 09:33 PM   #1
Water Heater Leaking at top pipes
What is the build up (usually blue, white or rust-colored) that is on the pipes (nipples) at the top of the tank, and does it 100% of the time indicate a leak at that pipe?
I appreciate your response!
Cheezhead is offline   Reply With Quote
Old 11-20-2007, 10:03 PM   #2
Send a message via AIM to Marlin
It's from the different metals reacting with one another, or from flux left on the pipe. Clean it off with a wire brush or sand cloth so you can tell whether or not it's leaking.
Marlin is offline   Reply With Quote
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 12:19 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Pipe nipples on water heater leaking big nate Plumbing 2 08-26-2007 02:02 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
