Water Heater Leaking From Cap - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2009, 02:16 PM   #1
water heater leaking from cap
i have a gas water heater that just started leaking from the top, from under the cap. can this be fixed and, if so, how?
2much2do is offline   Reply With Quote
Old 03-17-2009, 05:31 PM   #2
HVAC / Plumbing
Most likely it's from 1 of the water fittings that screws into the top of the tank
kenmac is offline   Reply With Quote
Old 03-17-2009, 05:38 PM   #3
Rewards Points: 1,548
I have had a fitting (a nipple) on a hot water tank top connection rust out. I was able to dig out the remains and screw on a new fitting and fix it.
If this is not the case then you have an ordinary tank failure and the heater is kaput, fubar, fini.
Old 03-17-2009, 05:43 PM   #4
Don't know it all, yet!
I had a GE go out on me a couple of months ago. I thought one of the connections was leaking but after checking and checking I called a plumber out to check and/or retighten or replace whatever. He told me that most likely since water was seeping from under the lid that the tank was gone.
Kudos to HD, they looked at the mfg date, verified that it was under warranty and replaced it!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Tags
appliance , plumbing , water heater leak
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
Water heater is leaking from the top lmlboone Plumbing 12 10-01-2008 03:18 PM
Water heater "leak"? TCinKC Plumbing 1 09-25-2008 12:01 PM
water pooling ontop of water heater nannerkrns Plumbing 2 09-23-2008 10:04 PM
"sticky" gas water heater thermostat homer12 Appliances 8 01-25-2008 04:36 PM
