Water Heater Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2008, 06:34 PM   #16
Rewards Points: 150
also there is a nut under the screw on the prv, how does that have to be adjusted with the screw?
econdave is offline   Reply With Quote
Old 08-17-2008, 07:06 PM   #17
electrical contractor
Rewards Points: 150
Dave you need to put about 90 pounds in the expansion tank. The nut on the PRV is to lock the setting of the screw, set the pressure with the adjusting screw, hold the screw so it will not turn, tighten the nut against the valve body with a wrench. This locks the screw so the pressure setting will not change.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 08-17-2008, 07:24 PM   #18
Rewards Points: 150
o.k, I shut the water at the street, pumped expansion tank to 100 psi, locked down the nut so pressure will stay its at 85 I am purging air out of system ie: opening all faucets. Anything else besides crossing fingers? and thanks in advance for all your HELP. and for hanging in there with me.
Old 08-17-2008, 07:27 PM   #19
Rewards Points: 150
Hope that takes care of your troubles
Jimmy
Old 08-17-2008, 07:30 PM   #20
Rewards Points: 150
so far so good, one last thing, I put a tire pressure gauge on the expansion tank and I get 50 psi, I put the electric pump on the tank and pump it to 100psi. I hope the electric pump gauge is the true reading.
Old 08-17-2008, 07:30 PM   #21
Rewards Points: 150
also, for a electrical contractor, your one hell of a plumber!!!!
Old 08-17-2008, 08:54 PM   #22
Journeyman Plumber
Ron The Plumber's Avatar
Your reducing valve is not working if you can't get it to drop the pressure to 50 or below, there set to 50 out of the factory. You might even think about it's replacement.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Pipe nipples on water heater leaking big nate Plumbing 2 08-26-2007 01:02 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 06:22 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
