Old 08-17-2008, 04:10 PM   #1
water heater leaking
just installed a new G.E. 50 gal. electric water heater. no leaks from piping, water is coming out relief valvem. about a pie plate size puddle sitting on water heater after about 1/2 hour or so. . I have 80 psi. coming in from street, expansion tank is at 60 psi. I have tried to put more air in expansion tank but cant. It says max is 150 psi on expansion tank. . is this my problem? not enough air in expansion tank? or something eles happening?
econdave is offline   Reply With Quote
Old 08-17-2008, 04:48 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes you need to exceed the working pressure on the house in the tank if it is at 80, either install a pressure reducing valve, or if there is one there, lower the pressure to 50, or pump the tank up to above 80 psi.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 08-17-2008, 04:53 PM   #3
Ron:
can you explain how to get more air in to exapanson tank. I used a electric air compressor and when I go to check pressure, water shoots out of valve and goes drops to 50 psi. Although compressor valve says there is 100lbs psi, I keep maxing out at 50. I cant lower pressure at street, I have a reducing valve there but thats as low as I can get it.
Old 08-17-2008, 04:59 PM   #4
Journeyman Plumber
Turn the water off at street. Relieve the pressure on the house, bleed off the expansion tank and recharge it to at least 90 psi, then turn house back on after you know for sure tank is at the desired pressure.
You know to reduce the pressure on the PRV valve you turn it left.
Old 08-17-2008, 05:29 PM   #5
reduce prv left as in counter clockwise?
Old 08-17-2008, 05:32 PM   #6
Journeyman Plumber
yes counter clockwise
Old 08-17-2008, 05:37 PM   #7
I just about have it turned all the way out and it still reads almost 90psi, is there a stop so the screw doesnt come out?
Old 08-17-2008, 05:38 PM   #8
Journeyman Plumber
Maybe I'm wrong, does the pressure decrease if you go clockwise?
Old 08-17-2008, 05:50 PM   #9
yes, it was up to 100 maxed out my gauge so I shut down and let opened basement sink. Scared the heck out of me. I pumped up expansion tank to 100 psi, says it can go 150psi max. am watching closely, am I on the right track?
Old 08-17-2008, 06:16 PM   #10
anyone there to help me? please I have been at this since 10:00 a.m.
Old 08-17-2008, 06:32 PM   #11
electrical contractor
Dave are you sure the gauge is right?
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 08-17-2008, 06:37 PM   #12
yes, it has always run around 90 psi since it was installed, I use to be on a well>
Old 08-17-2008, 06:45 PM   #13
Back the screw out of the PRV until you can turn it with your fingers, it should not blow out or leak any water. After screw is loose open a faucet and see if you have any water flow, it should flow only a second or two then pressure should go away, and gauge should drop to zero. If this does not occur, if you still have pressure you need to replace PRV.
Jimmy
Old 08-17-2008, 07:20 PM   #14
will do, thanks will let you know what happens'
Old 08-17-2008, 07:30 PM   #15
i did that and pressure dropped and water stopped. the valve says 25-75 psi but I am running around 80 according to gauge. Water tank is not leaking anymore, do I have to put air back in expansion tank? god I hope you are still there.
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Pipe nipples on water heater leaking big nate Plumbing 2 08-26-2007 02:02 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
