Water Heater Leak From The Top - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2011, 05:46 PM   #1
water heater leak from the top
my water heater is leaking from the hose that connects to my main water line. im trying to shut off the water to the water heater without shutting off water to the whole house, but i dont see a shut off valve any suggestions?
joaquin is offline   Reply With Quote
Old 10-09-2011, 06:31 PM   #2
Lightfoot's Avatar
Rewards Points: 272
if you don't have a shutoff, then turning off the main supply is likely your only option. You could shut off the main, install a shutoff at the heater, then turn main back on. Shouldn't take long.
Lightfoot is offline   Reply With Quote
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
