Water Heater Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2006, 07:18 PM   #1
Water heater leak?
I moved in to a house about 3 years ago and have noticed a trickle of water starting to pool at the base of the water heater. The heater is a Reliant 501. I know alot of houses with attic water heaters in Texas are burstin because of the heat. But mine is inside and the leaking is not substantial. My first thought was a spill, but after cleaning it up the pool came back in about two hours. Any other thoughts?
spydrtrbo is offline   Reply With Quote
Old 06-29-2006, 07:56 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Check all the connections first, if there all dry then suspect the tank could be leaking, replacement will be needed if the tank is the problem.
Ron The Plumber is offline   Reply With Quote
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 07:07 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
