-   -   Water heater leak? (http://www.diychatroom.com/f7/water-heater-leak-2893/)
spydrtrbo 06-28-2006 07:18 PM
Water heater leak?
I moved in to a house about 3 years ago and have noticed a trickle of water starting to pool at the base of the water heater. The heater is a Reliant 501. I know alot of houses with attic water heaters in Texas are burstin because of the heat. But mine is inside and the leaking is not substantial. My first thought was a spill, but after cleaning it up the pool came back in about two hours. Any other thoughts?
Ron The Plumber 06-29-2006 07:56 AM
Check all the connections first, if there all dry then suspect the tank could be leaking, replacement will be needed if the tank is the problem.
