Old 09-25-2008, 02:30 AM   #1
Default Water heater "leak"?
A couple days ago I noticed a very slow stream of water coming from what looked like my T/P valve on top of my water heater. The valve is right in the middle of the top of the heater. Dried it off with a towel and it looked like it was coming from the threads. The valve was pretty nasty - the tank is 8(?) years old - so I decided to just go ahead and install a shiny new one with some teflon tape. Flushed the tank while the water was off, then turned the water back on and nothing leaked from the threads.
I don't have a digital camera avaliable right now, but this pic is identical to mine
http://www.curbly.com/uploads/photos...full_large.jpg
The strange part (and here's what I completely don't understand!) is water came out from around the base of the threads - i guess straight through the "rust ring" around them, but did not spray out like water under pressure does. It does not run off the top now, but if I turn on the hot water on a sink and play with the cold water inlet valve the water goes up and down accordingly - it fluctuates just enough to rise to the top of the heater but goes back down below the top. Nothing sprays out. Any ideas???
Tony
TCinKC is offline   Reply With Quote
Old 09-25-2008, 02:01 PM   #2
Building codes guy, Mod
thekctermite's Avatar
At 8 years old, it could be the connection corroding and a pinhole leak resulting from the corrosion. Our water around here seems to eat anode rods and then tanks pretty quickly.
I'd rule out a faulty connection from the T&P to the tank first though. How many wraps of teflon tape did you make? It will take at least 6 or 7. You also really need the T&P tight.
Did you open the T&P, i.e. test it? If you did, they rarely reseal and must usually be replaced. It could be slowly leaking due to that. Put the new one in and leave it alone.
If all that doesn't work, I'd recommend a new tank.
thekctermite is offline   Reply With Quote
More On This Topic
Hi! I am Drew Fenn professional home inspector. I am here for Expertvillage.com. Today, we are going to install a shower head and I will show you how and the video is produced by Black Dog Video. You can blackdogvideo.biz on the internet. This is how the... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I'll show you how to drain the tank of your air compressor. All compressed air systems generate condensation inside of the tanks, now if you don't drain the tanks on a regular bases rust will... Read More »
Ok, so on the new oven on the new stove, the gas inlet is here. So that's where the gas is going to go in and then it goes into a regulator and then goes to the valves and to the burners. So we're going to need the fitting which will go into this, this... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 05:32 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 10:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 05:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 08:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
