Water Heater Last 5 Minutes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2010, 07:00 PM   #31
Leak Master
Originally Posted by Yoyizit View Post
I thought the temperature coefficient of resistance for Nichrome was pretty small, much better than for tungsten.
http://www.allaboutcircuits.com/vol_1/chpt_12/6.html
So how much can you expect for the cold resistance of a 4500w Nichrome element?
How 'bout at cherry red [800 to 1000C]?
I see by the amount of your posts that obviously you are active on this site, and therefore must have a good idea what you are talking about. With me being new to this site, I was wanting to keep it as simple as possible for the normal DIY, so.... I am wondering what all this additional information adds to the conversation? Why not start another thread?
O'Leaky is offline   Reply With Quote
Old 05-23-2010, 07:10 PM   #32
Originally Posted by jlew47 View Post
No brainer. Got power to the unit? Buy a new one!
why would you toss the old one if he has heat on the upper element and maybe just needs the lower
The older I get the better I was
Old 05-23-2010, 07:55 PM   #33
Rewards Points: 1,532
It could also be the lower thermostat in place of a bad element. Either one is much less money and effort than a new heater. But a 10-year old heater is potentially worth replacing at least for knowing it is new.
If you do buy a new one, put a water heater drain pain under it if the old one doesn't have one.
bob22 is offline   Reply With Quote
Old 05-23-2010, 08:00 PM   #34
Licensed Master Plumber
It only takes about 10 minutes to check the elements. I'll bet the lower is bad
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 05-23-2010, 08:12 PM   #35
agree: could try
http://www.inspectapedia.com/plumbin...Hot_Water5.htm
Always turn off electricity when doing this!!!!!!!!!!!!!!!!!!!!
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
