Water Heater Installed In Unfinished Bonus Room. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2010, 08:17 AM   #1
water heater installed in unfinished bonus room.
I bought a new home in November of 2009. It has an unfinished bonus room which approximately 400 square feet and it has 1 window. This room is where the water heater is located. If I want to finish this room out and enclose the water heater behind a door, do I have to do any additional vent work or is it fine the way it was installed?
scubamike is offline   Reply With Quote
Old 03-25-2010, 09:18 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it electric or gas?
Journeyman Plumber
Old 03-25-2010, 09:58 AM   #3
It's gas and it is vented. I guess my question is do I need to do anything else? Regular door, vented?
Old 03-25-2010, 10:19 AM   #4
Rewards Points: 1,532
There must be provision for combustion air, or makeup air, entering the closet where the water heater is, in addition to the exhaust vent or chimney.
There are formulas based on the cubic feet of the closet but the typical method of providing combustion air is to put a louver in the closet door near the bottom.
When there are other heating devices, such as a furnace, in the room, additional vents to the outside may be needed depending on the total BTU and the cubic feet of the entire room or basement.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
