Old 11-03-2012, 10:20 AM   #1
Water Heater install
The new heaters I am installing do not have legs/feet. Should I stand them on bricks? to keep them out of any potential leak?
digitalplumber is offline   Reply With Quote
Old 11-03-2012, 10:41 AM   #2
Gas or elecric? Where are they going to be located?
You do plan on having them sitting in a pan with an outside drain, right?
Old 11-03-2012, 10:59 AM   #3
Gas. replacing old
Attic
Yes in pan drained to outside
These are bradford whites. Manual just indicates to set in pan.
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
