Water Heater Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2012, 08:47 AM   #1
Water heater install
Hey,
Installing an A.O. Smith Pro Max power vent water heater.
Do I need to install a drip tee in the exhaust before going through the outside wall?
Do I need an expansion tank?
If so, where does it go? What does it do?
Thanks,
Dave
Bluehawks is offline   Reply With Quote
Old 01-17-2012, 09:11 AM   #2
Rewards Points: 1,418
You do need an expansion tank. It should go in the cold water line between the cold water shutoff and the tank inlet. It provides an air cushion. Each tankful of water will expand a little when heated and can trip the temperature/pressure relief valve if there is no expansion tank.
(The expansion tank will work anywhere provided there is no closed valve between it and the water heater but the inspector likes to see it quickly when he looks at the water heater.)
I have not read about drip tees in flues but I have heard about water vapor condensing in the flue and running back down into the furnace or water heater.
Old 01-17-2012, 10:24 AM   #3
Rewards Points: 1,520
Might read:
http://www.hotwater.com/lit/im/res_gas/315465-000.pdf
talks about venting the unit and what to do about condensate.
bob22 is offline   Reply With Quote
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
New Electric Water Heater Install RustyRealtor Plumbing 11 04-17-2009 07:38 AM
Tankless Water Heater Install - Completed Reilley Plumbing 0 02-08-2009 09:37 PM
