Water Heater Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2011, 03:02 PM   #1
Lightfoot's Avatar
Rewards Points: 272
water heater install
I have a few questions.
Replacing a 50 gal electric with a 50 gal electric, pipes come in over unit with plenty of room. I want to change the plumbing a bit and add some shutoffs (doesn't have any now) and stainless braided flex lines. With brass 1/4 turn shutoffs connecting to galvanized-will i need to do anything special? Right now there are galvanized unions connecting it. I want to take off the unions, put brass shutoffs in place, then run flex lines to the top of the tank. Should i use sealant tape or pipe dope for connection? T/P relief valve will run outside with existing pipe. Also are the new aluminum pans for setting the heater in, worth the 20 bucks or is it a waste? The present unit hasn't been leaking or anything but it's 22 y/o and i think one of the elements is out so rather than spend money on an old unit, i think i'll take the opportunity to just change it out. I just wondered about mainly hooking brass to galvanized-or do i worry too much?
Lightfoot is offline   Reply With Quote
Old 07-28-2011, 01:01 PM   #2
Lightfoot's Avatar
Rewards Points: 272
well obviously there aren't any BIG issues with what i plan to do or someone here would have surely chimed in. thanks anyway.
off i go!
Old 07-28-2011, 01:06 PM   #3
DIY staff
Rewards Points: 7,174
Brass valves to galvanized is fine!----
Lightfoot (07-28-2011)
Old 07-28-2011, 01:07 PM   #4
Lightfoot's Avatar
Rewards Points: 272
Thanks Mike! That was my main concern.
Old 07-28-2011, 01:13 PM   #5
Experienced
Jackofall1's Avatar
Maybe I am missing something, but without unions how will you complete the connections?
Additionally I would bet those unions are "Diaelectric Unions" which prevent corrosion of dissimilar metals.
Mark
Old 07-28-2011, 03:11 PM   #6
Lightfoot's Avatar
Rewards Points: 272
Mark
flex lines from the shutoffs to the heater.
thanks!
Old 07-28-2011, 04:56 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I do not like the SS braided flex lines, I think the corrugated copper flexes are better/stronger.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 07-28-2011, 05:29 PM   #8
Lightfoot's Avatar
Rewards Points: 272
Thanks rj, i'll keep that in mind. I'll probably end up going with whichever is cheaper.
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
New Electric Water Heater Install RustyRealtor Plumbing 11 04-17-2009 07:38 AM
Tankless Water Heater Install - Completed Reilley Plumbing 0 02-08-2009 09:37 PM
