Water Heater Inlet Nipples Rusting. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2010, 06:51 PM   #1
Water heater inlet nipples rusting.
We had our gas water heater replaced on 1-30-10. I noticed corrosion on the nipples leading into the water heater. Most of the corrosion is on the cold side with just a spot on the hot side. What would cause this only 8 months after installation? I have a dehumidifier and donít have any other rust issues in the basement. Pictures attached.
Thanks,
Mark
Water heater inlet nipples rusting.-cold.jpg   Water heater inlet nipples rusting.-hot.jpg
MarkHipp is offline   Reply With Quote
Old 09-22-2010, 09:27 PM   #2
HVAC / Plumbing
maybe a small water leak there. Looks like insulated unions
kenmac is offline   Reply With Quote
Old 09-22-2010, 09:36 PM   #3
the Musigician
DangerMouse's Avatar
Condensation could still be the cause on the cold line, but the hot has me puzzled.
Normally that line should be too warm to condensate.
DM
Old 09-23-2010, 12:33 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 354
Did you hire someone to install your heater?
If so, call them back and get it fixed under warranty. Its been less then 1 year. You should be covered
settings for indirect water heater doug32 Plumbing 0 07-14-2010 07:04 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
