Old 01-09-2008, 10:58 PM   #1
Water heater hot outlet union leaking
Outlet has a 3/4 nipple screwed in, then a 3/4 metal (appears to be galvanized) union going into another 3/4 nipple soldered to copper piper.
Water started leaking from the union today. Tonight I disconnected, cleaned and used teflon tape on the threads of the union but it still leaks after two attempts.
Other than replacing the union are there any other suggestions?
Should I be using pipe dope instead of teflon tape?
Thanks in advance,
Jay in Illinois
dog193 is offline   Reply With Quote
Old 01-09-2008, 11:46 PM   #2
Bathtub Refinisher
Exactly where is the union leaking. Where the two halves go together or on either side?
tubguy is offline   Reply With Quote
Old 01-09-2008, 11:56 PM   #3
It's leaking around where the big nut joins the two pieces together, water is coming up through the threads.
Old 01-10-2008, 07:14 AM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,......
Those fittings seal against their Faces,... No need for Tape or Sealant.....
My 1st Guess is,... Your's has corroded or rusted,+ Probably needs to be Replaced.....
Old 01-10-2008, 10:07 AM   #5
Bathtub Refinisher
It is odd that it started leaking out of the blue. You could try using pipe dope on the threads and use 2 big wrenches to tighten things back up. Hope it works.
Mike
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Pipe nipples on water heater leaking big nate Plumbing 2 08-26-2007 02:02 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
